My daughter's Fiesta has a rumbling noise which varies directly with road speed. I suspected wheel bearings or differential bearings. On inspection there was/is no oil leakage from the gearbox, and no discernable play or roughness felt from either wheel bearing.
I jacked-up the nearside wheel, leaving the offside wheel on the ground, and ran the engine at 2000rpm in second gear, no abnormal noise was heard.
I repeated the test with just the offside wheel raised, and the abnormal noises returned.
From the above, and a bit of listening for the source of the noise I determined that the driveshaft support bearing was causing the noise.
So to my questions:
1. Is this shaft bearing prone to failure, and therefore the most likely fault?
2. Assuming the driveshaft has been removed, what likely problems can be encountered in changing that bearing?
MM
So to my questions:
MM
