We're in the middle of a garage conversion and we're filling in the single door and the garage large door.
We've sourced a second hand large double patio door which is 1780 wide whereas our opening is about 2178. It's about 200 either side.
I know there are frame add-ons and extenders to fill in these gaps, but given the size that needs to be filled in, it seems too much of a gap to drive through a screw in which is just a hollow filling to grip the brick on the other side of the extender.
An alternative is running a 100mm treated timber batten around the sides to reduce the gap, secure these to the wall and then secure the doors to these battens and bite into the brick also. Wouldn't this be a better option?
I can use fascia trim to cover the batten.
