20mm Plastic Trunking
Generally speaking, pvc conduit is no good outside. You'd have to rely on glue to make the joins watertight.
One probably would if one wanted/needed to make the joints watertight - but why would one want that? (not that, I hasten to add, would I use PVC conduit outdoors!)
Kind Regards, John
What?
Are you asking why would one want the joints watertight outside??
There are circumstances where the conduit only enters the bottoms of the accessories, and the conduit doesn't strictly speaking need to be watertight, if there are drainage points.
Usually pvc conduit outside is more trouble than it's worth IMO.
There should always be drainage points at the lowest points of the conduit so I'm not sure what your point is.
Even if conduit is watertight the fact remains that condensation will occur within it, and without drainage holes it will not be able to escape.
What? Are you asking why would one want the joints watertight outside??
Indeed - given that the conduit is only there for questionable aesthetic and 'protection' (mainly UV) purposes (not to protect cable from water), and ...
As Risteard has said, there should always be adequate drainage points, even if one thinks the conduit and its connections are watertight.
I couldn't agree more.
Kind Regards, John
Plumbers overflow pipe is much cheaper and does the job as well, or badly depending on your point of view.
Ok the general view is its no good, overflow pipe normally lives outdoors and I assume it would be ok I will look into this as a option.
But normally is run in relatively short lengths.
2 or 3 metre lengths.
Interfacing it with conduit boxes is a problem. But some is a tight fit over plastic conduit, i.e. The i.d. Of overflow pipe is the same as the o.d. of conduit.
But no good to fit in 20mm conduit adapters.
The i.d. of overflow pipe is the same as the o.d. of conduit.
So a short length of conduit, say 50mm, as an interface.
Yes I understand that it could be cobbled together somehow.
But I don’t understand what would be gained. Is the PVC used in water overflow pipes radically different from standard PVC conduit used for electrical installations?
