Commercial coffee machines used in shops etc require a quick heat recovery on the water, and therefore use large elements. They are typically split across the phases, but can be commoned up and run from a single phase supply - if the spec says so (the motors may also be 3ph for the grinder and pumps etc?).
Typically you will find they are anywhere from 10amp TP or 30amp SP upwards
