230/400V Coffee Machine
7 Feb 2006
Leeds
Good morning
I'm considering buying a commercial coffee machine for home however the one I'm looking at is 230/400v.
question - what do I need to run this from a domestic supply?
Many thanks
images
but this assumes its rated at less than 13A @230v
Thanks it did seem a daft question ifI waited until it arrived I'd have seen the plug!
Cheers
Why would anyone, anywhere, ever need a 3 phase coffee machine?! What is the reason for it being 3 phase?!
Commercial coffee machines used in shops etc require a quick heat recovery on the water, and therefore use large elements. They are typically split across the phases, but can be commoned up and run from a single phase supply - if the spec says so (the motors may also be 3ph for the grinder and pumps etc?).
Typically you will find they are anywhere from 10amp TP or 30amp SP upwards
