You are obviously entitled to that opinion but, needless to say, I would not agree. I did say that your suggestion was interesting.
I didn't say that at all.....
You didn't, but ....
I was talking about a very specific case of the cable in a ring final. This is the only situation where the cable rating and the over-current protection rating are different.
... the only situation in which the cable rating and OPD rating are different
in that direction. As I illustrated there are very common situations in which the difference is much more dramatic in the other situation - such as my example of the common situation of a cable with a CCC of 20A being protected by by a 6A OPD.
Which is, of course, nonsense in the case of the ring final.
As I wrote, an interesting (and arguable) suggestion. However, whilst it may be 'nonsense' in terms of design, that may not be true in terms of usage (over which the designer has no control in the case of a sockets circuit). Provided only that there are sufficient socket outlets sufficiently close to one end of the ring, a user may cause more than 20A to flow in the short leg of a 32A ring final. That is an unavoidable 'feature' of the ring final as allowed by BS7671.
I guess you are proposing that it is OK for the cable to melt as long as the connector stays intact.
Not at all. The connector has no bearing on the theoretical possibility of any of the cable becoming overloaded, and (in the situation we are discussing) no connector is ever going to come to any harm as a result of the current flowing between the conductors 'joined' in it.
As has been suggested by others, this whole discussion about the 'current rating of terminals/connectors' is really pretty moot, since it is (at least, in my opinion) essentially plain nonsense. All that matters is that the physical capacity of the terminals is appropriate for the size of conductors, since the vast majority of current will go directly through the contact between conductors, with very little actually going through the material of the terminal.
In fact, my personal view is that the most important thing is
not to use a connector with terminals which have 'too high' a 'current rating', since such terminals are likely to have too large a physical conductor capacity, which is the situation in which contact between the conductors may be less than ideal.
