    Dismiss Notice
30m2 outbuilding
Discussion in 'Building Regulations and Planning Permission' started by Oddbod1, 9 Jun 2017.
  1. Oddbod1
    Oddbod1
    28 Mar 2017
    96
    Thanks Received:
    Aberdeen
    Country:
    Does the max 30m2 outbuilding under PD refer to internal sizes or should I include external wall to external wall ie inclusive of cavity in the overall 30m2 calculation?
  2. Sponsored Links
  3. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,781
    Thanks Received:
    593
    Country:
    This was asked in the last 6 months but I can't remember the answer
    I have a feeling it was internal- which surprised me
  4. tony1851
    tony1851
    23 Feb 2012
    9,883
    Thanks Received:
    1,483
    Manchester
    Country:
    It's floor area (ie internal measurements).
  5. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
    The only 30m rule I know is for not needing building regs approval, nothing to do with PD. For PD chances are the only size rule would be the one saying you can't cover more then half your garden.
  6. tony1851
    tony1851
    23 Feb 2012
    9,883
    Thanks Received:
    1,483
    Manchester
    Country:
    ^ Correct! (should have read it more carefully; of course 30m² only applies to Building Regs).
  7. Oddbod1
    Oddbod1
    28 Mar 2017
    96
    Thanks Received:
    Aberdeen
    Country:
    Correct, it is for building regs. I just mention PD because it's not subject to a planning application.
  8. RichA
    RichA
    3 Aug 2005
    640
    Thanks Received:
    27
    Surrey Hills
    Country:
    It might be, PD is dependent on other things (ridge/eaves height, etc).
  9. Oddbod1
    Oddbod1
    28 Mar 2017
    96
    Thanks Received:
    Aberdeen
    Country:
    Hopefully, someone can provide a definitive answer.
  10. Sponsored Links
  11. RichA
    RichA
    3 Aug 2005
    640
    Thanks Received:
    27
    Surrey Hills
    Country:
    Are you interested in PD/Planning (right to build) or Building Regs (how you build)?
    Have a look at this:
    https://ecab.planningportal.co.uk/uploads/miniguides/outbuildings/Outbuildings.pdf
    Outbuildings are considered to be permitted development, not needing planning permission, subject to the following limits and conditions:
    • No outbuilding on land forward of a wall forming the principal elevation.
    • Outbuildings and garages to be single storey with maximum eaves height of 2.5 metres and maximum overall height of four metres with a dual pitched roof or three metres for any other roof.
    • Maximum height of 2.5 metres in the case of a building, enclosure or container within two metres of a boundary of the curtilage of the dwellinghouse.
    • No verandas, balconies or raised platforms.
    • No more than half the area of land around the "original house"* would be covered by additions or other buildings.
    • In National Parks, the Broads, Areas of Outstanding Natural Beauty and World Heritage Sites the maximum area to be covered by buildings, enclosures, containers and pools more than 20 metres from house to be limited to 10 square metres.
    • On designated land* buildings, enclosures, containers and pools at the side of properties will require planning permission.
    • Within the curtilage of listed buildings any outbuilding will require planning permission.
  12. Oddbod1
    Oddbod1
    28 Mar 2017
    96
    Thanks Received:
    Aberdeen
    Country:
    Well mainly building regs, but I want to make sure I dont fall outside the scope of PD either because I dont you can build a 40m2 outbuilding under PD even if you get building regs approval?
    So on that logic, if I am building an outbuilding of 30m2 which is internal size, and I dont account for a cavity wall which might add another 9m2 square for the external area bit, then I fall foul of the need to get building regs approval and PD rules.
    Basically I just need to know that I dont fall outside of PD or need building regs if the internal area of the building is 30m2.
  13. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
  14. tony1851
    tony1851
    23 Feb 2012
    9,883
    Thanks Received:
    1,483
    Manchester
    Country:
    It's internal floor area which must be < 30m², not overall footprint, for Building Regs.
    • Like Like x 1
  15. Oddbod1
    Oddbod1
    28 Mar 2017
    96
    Thanks Received:
    Aberdeen
    Country:
    Thanks, that was the answer I was looking for. Can I ask where this is verified or confirmed?
  16. RichA
    RichA
    3 Aug 2005
    640
    Thanks Received:
    27
    Surrey Hills
    Country:
    Did you read these docs?
    If the floor area of the building is between 15 square metres and 30 square metres, you will not normally be required to apply for building regulations approval providing that the building contains NO sleeping accommodation and is either at least one metre from any boundary or it is constructed of substantially non-combustible materials.
  17. Oddbod1
    Oddbod1
    28 Mar 2017
    96
    Thanks Received:
    Aberdeen
    Country:
    I did indeed read that but I guess I was looking for some sort of written confirmation that the definition of floor area does not include the overall footprint of the building (inc cavity).
Loading...
Share This Page
