    Dismiss Notice
3rd system in 12 years
Discussion in 'Plumbing and Central Heating' started by JohnH74, 19 Sep 2017.
  1. picasso
    picasso
    8 Apr 2008
    10,495
    Thanks Received:
    2,611
    Essex
    Country:
    what model vaillant do you have ?
  2. JohnH74
    JohnH74
    2 Mar 2009
    13
    Thanks Received:
    Derby
    Country:
    I have spoken to them a few times and all they say is "it is quite old and we don't build them with internal stuff anymore"(I guess for this reason).
    I am not sure what the warranty period is. I bought it in 2009.
    A new one will be around £1200
    If the internal phe is knackered, how would fitting an external phe stop the overpressuring? The internal knackered one is still there.
  3. Sponsored Links
  4. Roger928
    Roger928
    10 Aug 2016
    2,631
    Thanks Received:
    201
    Country:
    The old one is disconnected. The old dhw tappings are plugged.
    All the connections to the new phe become external.
    Your warranty is probably null and void...
    EnergyManager thermal store cylinder
    It is important to have the cylinder serviced annually to ensure safe operation and as a requirement of the warranty. To qualify for the warranty a record must be kept in this guide.
  5. JohnH74
    JohnH74
    2 Mar 2009
    13
    Thanks Received:
    Derby
    Country:
    Hi Picasso,
    It is an EcoTec Plus 637, fitted at same time
  6. Sponsored Links
  7. picasso
    picasso
    8 Apr 2008
    10,495
    Thanks Received:
    2,611
    Essex
    Country:
    Was kinda hoping it was a combi (passing filling loop would explain a lot) Its might be possible to cut out the internal phe and let it drop inside the cylinder then fit an external phe with pump and flow switch on to the existing dhw connections.
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
