4.4kW on a plug?
  • Thread starter Thread starter Newboy
  • Start date Start date
N
Newboy
Doing some minor works at a clients house and was surprised to find a build-under double oven (with a rating plate 4400W) connected via flex (don't know CSA) & plug(top) to an unswitched 1 gang socket switched above worktop by 45 amp DP cooker switch.
Diversity or cr*p installation?
Interesting.
Using the standard diversity calculation you get less than 13A.
So if a circuit with a cable with a CCC of 13A was used, and a 13A OPD used, all would be well.
So why not this?
Seems to be the case - top and bottom oven seem to work with no interlock to prevent simultaneous use.
The only thing I can think of is that there is a grill element in addition to the top oven element - possibly taking the total load to 4.4kW but not possible with two elements alone.
Can't track down an manual for the product - despite checking all the usual sources and the manufacturer.
Appliance has been in use for over 10 years - plug(top), flex & socket all look undamaged
As it should be.
If I bought a double oven and found I could only use one at a time I'd be returning it toot sweet.
You probably can't use the grill and the top oven at the same time.
The maker might have just added up all 3 elements and got 4.4kW - as EFLI says, it's a strange amount, as it busts the oh-so-common 16A. Don't suppose you noticed if it was made for a market where 3-phase is common?
Which prompts me to repeat my question.
Everyone is happy with IbInIz when Ib is found using the normal diversity calculation, and In & Iz are 16, or 20, or 32 etc.
So why not when it's 12.7 ≤ 13 ≤ {whatever the flex is}?
I think it is applicable with a double oven
but
IF all 4.4kW were on or off together and only switching on and off with the thermostat I would not be so comfortable with it being on a plug.
