4 port USB 2 hub
6 May 2010
West Midlands
Do these work on PS3 USB. I thought they would but I used one for an XCM cross battle adapter and it won't work. :cry: :cry:
There's no reason the hub shouldn't work.
That's what I thought. The XCM works direct into the PS3. Also I have a 1.1 4 port hub that it works through that but the USB 2 will not work and I have tried 3 already. ;)
I have just heard from XCM and they say:
"It is better to plug the cross battle adapter directly to the ps3 port, the USB hub may not supported"
Seems bizarre to me. :eek:
I would say this XCM thing is not properly USB compliant. Not uncommon.
I've had trouble with USB splitters on PC's as well as PS. It's all fine and good with low access devices, as it operates at a lower speed, it's when high speed devices need to access the USB, the hub then needs to be powered, to amp up the signal. I think USB3 will be even worse.
Double DIN USB overcame this, as that carries power, but wasn't used mainstream.
One solution it to upgrade the psu in the ps3. (or pc).
There's no such thing as a USB splitter..
Uh, no, the signal doesn't need amplifying, and powered hubs have nothing to do with high speed devices.
I think you should come back after reading the specification.
Because replacement PSUs for PS3s are so easy to come by.
Are they easy to get??? I wouldn't want to teardown my PS3 until the warranty has elapsed - it has a few months to go. :D
I have had Xbox 360s to bits more times than I like to admit. :cry: What a pain even with the separating tool. ;)
Don't get me wrong, the XCM Cross Battle Adapter 2.0 is brilliant. I can put the firing on the triggers. For some reason Sony think firing should be on the bumpers - possibly cos the basic triggers are sooooooo badly designed but can be improved with trigger adapters. Also the D pad/left stick on the Xbox controller are in the right place. And finally, I can use the same controller for both consoles (thought the Xbox is now rarely used) so the XCM is really something I would never want to stop using. :D
Phew, what a plug for XCM. :D :D
That was sarcasm. A whole lot of it. There is absolutely no need to change the PSU in your PS3 and it won't make any difference to the performance of a USB hub.
I thought so but I just had to check. ;)
I nearly got out the Torx. :D Only kidding. ;)
Thanks for the help BTW.:cool:
So my 4 port USB isn't splitting 1 USB socket, into 4 ? That's NOT the definition of a splitter?
Powered hubs have nothing to do with high speed devices? So why do my High speed powered devices, when attached to the computer ask for a powered hub?
I read the spec..nothing useful. vs usb double din.
Upgrade the PS3 PSU so you never built a circuit or know anything about electronics?
Why do people with no idea post into forums?
No, it isn't. If you want to call it something other than a hub, call it a port expander.
How, exactly, are your devices powered by high speed? You simply have devices which require more than one unit (100mA@5VDC) of power. This has nothing to do with their speed; I have a half dozen devices within eyesight which operate at high speed without using more than one unit.
That would be because the USB 3.0 spec says nothing about 'usb double din', which isn't a standard. I was actually referring to power requirements.
Oh, I've built circuits. I know all about electronics. I'm still wondering how upgrading the PSU in a device which already has an over-specced PSU is going to change how the USB protocol works.
Yes, why are you posting here?
