If an earthed extraneous-conductive-part comes into contact with an energised circuit conductor, will the circuit be disconnected within an acceptable time frame?
It appears that you need to ask yourselves two simple questions:
Would we expect to find any dangerous potential difference between two circuit protective conductors supplied via the same distribution system?
The answer to the first question should be yes and the second question should be no, given that your loop impedences are within acceptable parameters. Therefore even though we highlight two different funtions of safety earthing, both supplementary bonding conductors and circuit protective conductors perform both functions adequately.
give your considered opinion as to whether this man should be bonded to earth,
Let's start at the beginning with the EAWR:
The EAWR only talks in terms of 'conductors' and 'circuit conductors', it tells us that "all conductors (other than 'circuit conductors') must be connected to earth.
BS 7671 : 1991 simply expands upon the EAWR, it subdivides 'conductors' into two catergories; Exposed-conductive-parts and Extraneous-conductive-parts. It then gives us a set of 'loop impedence' figures and we are told that if we stay inside the parameters of the 'loop impedence' values, any fault currents that occur will be unable to reach such a magnitude for a sufficient duration of time to cause death or serious injury.
This theory is known as 'Earthed equipotential bonding and automatic disconnection of supply', it requires both 'circuit protective conductors' to supply an earth to fixed and portable electrical appliances (that may have exposed-conductive-parts) and 'supplementary bonding conductors' to supply an earth to 'conductors' that do not form part of the electrical installation (extraneous-conductive-parts). Therefore all 'conductors' that may be simultaneously accessible are connected to earth via the same earthing system, no two points of which should have a resistance between them that will allow a potential difference of greater than about 50v if a fault directly to earth should occur, because no matter which 'conductor' (exposed or extraneous) has become hazardous live having come into contact with a 'circuit conductor', we have supplied a low resistance earth path which will allow enough cuurent to flow to the mass of the earth quickly enough for the over-current protective device to disconnect the circuit within a specified time.
At the time the fault occurs the entire earthing system will become live for a moment but the fault current will be on its' way to the mass of the earth, therefore anybody who is in contact with an earthed 'conductor' will only be in parallel or 'indirect contact'. Anybody who is in simultaneous contact with two 'conductors' will only receive a shock of less than about 50v before the supply is automatically disconnected.
Compare the above to leaving 'conductors' not connected to earth:
If an un-earthed radiator comes into contact with a damaged 'circuit conductor', the radiator will simply become and remain 'hazardous live', anybody who touches the radiator (or any of the radiators if the water in the system is old) will become a series, high resistance path to earth and unless the shock exceeds 30mA (which is unlikely indoors) there is no reason why the supply should be automatically disconnected!
Summary:
Both 'circuit protective conductors' and 'supplementary bonding conductors' return 'earth leakage current' and 'earth fault current' to the mass of the earth, as long as 'loop impedence' readings are within given values, neither earth leakage current nor earth fault current will be allowed reach a magnitude or duration as to cause serious injury or death.
PS
The problem with the 16th Edition is that some definitions were taken straight out of the 15th Edition without being updated:
eg. Indirect contact - should have read;
Contact of persons or livestock with earthed conductive parts which have become live under fault conditions.
PPS
In between the EAWR 1989 & BS 7671 : 1991, a book was written called "The Electricity at Work Regulations 1989 An Open Learning Course 1990" by an outfit calling themselves THELA. This book is written in four sections, the first of which goes to great lengths to make sure the reader understands the difference between a 'conductor' and a 'circuit conductor'. Unfortunatey the other sections of the book appear to have been written by people who hadn't read the first section, as they go on to talk in terms of "electrical conductors" (a term which isn't used in Regulation 8 of the EAWR), as a result this book confused the living daylights out of everybody before the 16th Edition was even published.
If a circuit conductor comes into contact with the earthed steelwork of a building, how is the leaking current returned to the mass of the earth?
