an RCD doesn't work indoors
Being indoors or outdoors isn't what causes an RCD to trip, dummy.
You really aren't cut out for this, are you?
The RCD will prevent a shock of 30mA, but will not prevent a shock of an extended duration of a magnitude of less than 30mA
The EAWR only cover activities, systems etc to do with work, not DIY.What I have quoted above is exactly as it appears within the Electricity at Work Regulations 1989 (which is still UK Law).
Damn. I was hoping to see more drivel from this joker.
Be careful what you wish for.
RCDs do not prevent electric shock. It will not not limit the shock current to 30mA or less either.
All an RCD does is limit the shock duration.
I just have a sneeky feeling he is one of the regulars on here under a different guise................
Therefore the only logical conclusion is that the author of this publication created it specifically to rile others and cause dissent.
No, no, no.. he's not a troll.
I don't think he means any mischief; he's just confused
Don't talk such rubbish, I don't have an RCD on any of my upstairs circuits.There appears to be two points still to raise:
Point one; is that there still appears to be a number of you who are prepared to theorise about a subject that is very easy to prove, if you are not prepared to go upstairs and touch an energised circuit conductor please do not come on here shouting your mouths off on your theories about what RCD's can or cannot do.
The EAWR do not apply to DIY in your own home.Point two; the EAWR applies whilst people are at work and whilst installation work is being undertaken.....
