Blink and you'll miss that on the DISQ course, and it's not (AFAIK) mentioned in either the OSG or the EGTTBR.....Always thought should be through same hole or a slot between them.
The point of my question...If you do it this way then you get eddy currents which will heat up the metal given enough current through the tails
It's pretty well buried there too, with just a single sentence. Nor does the grey book give it any more prominence.and as it's in the brown book they should have done it properly!!
Lovely....All the new circuits are done as per usual new council work - SURFACE MOUNTED AND IN TRUNKING -
Only time I have seen the slot method
