Hi
Please take a look at the images below. We had a 2 story extension done 5 months ago.
I would expect some cracking inside with the change of season etc, however vertically where 2 walls meet inside the plaster upstairs and downstairs has cracked right the way down. This on its own is not necessarily a huge worry but as you will see from the images the mortor join outside also seems to be 'pulling away' a little from the existing house. Its around 3mm when maybe 3 months ago it was 0mm.
I saw that the bricklayer used these strange brick tie things to connect the existing to the extension, and at the time it just seemed a really light weight way of doing it.
Basically there were strips fixed vertically to the existing house and these right angled ties clips into the vertical strips and between the mortor or around every 3 bricks of the extension.
Should I be worried?
[/img]
