AC - Ford Galaxy
30 Mar 2010
Rhondda Cynon Taff
Had it re-gassed a year ago.
The other day stopped working. Then it started again and has been off/on ever since. Display shows AC on. Also, when Iturn it off I can hear it starting every time.
Took it to halfords. They said machine showed ZERO. But surely it would work not all if this was the case?
They want me to take it back tomorrow so they can use nitrgoen to check for leaks?
As far as I know Halfords only use those diy aerosol kits for their A/C refilling service. I can't see them having nitrogen to use. Is one of the pipes from your A/C compressor cold when it's running? If so, it's working, unless the pressure is borderline when I suppose it could be intermittent.
I guess the only thing you can do is to have the system re gassed, together with a dye that fluoresces under UV light - great when looking for leaks.
Some firms like Kwik Fit will fill the system and if it leaks out within 24 hours or so, you aren't charged.
John :)
Isn't it illegal to refill a system if you know it's leaking because of pollution laws? That's why nitrogen is used. I assume you can still use a dye .
The only time I would ever use kwik fit is for the purpose stated above, I’ve had my money back when it didn’t work out.
Great systems when they are working but seem to be a pain after major components have been replaced and the system has been opened.
YES. Big fines from DEFRA if you get caught! However, I've never heard of anyone getting caught!
