Accenta 6 Instructions (with specific keypad)
16 Sep 2007
Lancashire
I’m trying to get documentation together for renting a property, but am struggling to find the instructions for the Accenta 6 with the keypad as shown below:
aa1a77d8-406f-4232-8686-b4ab2c28072c-jpeg.146393
I have found plenty of instructions that show a different keypad (think it is the HWLEDKP having searched Amazon for a similar type), but nothing with the type above.
Any pointers to the location of such a manual gratefully received, or confirmation that the instructions for the HWLEDKP keypad would also be applicable to the one in the photo.
Many thanks.
Do not give the tenants the instruction manual.
Give them a short version on how to set and unset the alarm and part set if required .
Make your own up.
If you give them the instructions then they can change the code number ,this could lock you out of the alarm system which would require you to default the control panel to get the user code back.
Good thinking - thanks for that advice. I'll try and edit the manual I have found just to show the basic set/unset as you suggested.
Cheers.
Apologies - forgot to say that Honeywell have provided me with the Engineers Manual, so at least now I’ve managed to sort out the zoning on the alarm!!
tonymc, did you manage to find an instruction manual? I’ve recently moved into a property with this alarm but previous owner has left no information on how to use it. Can you please let me know where I can locate the manual? Thanks
