Accenta 8 mini with sonade 2000
7 Dec 2018
Hi all,
I need to remove battery from both of the above and then turn off the mains power. I was going To go into engineer mode and then open up sonade, disconnect pos and neg leads from battery then open up accenta and disconnect battery and then finally turn off mains power. Does anyone know if there are any issues doing this.
Victor
When you open the bell box and disconnect the battery it will ( should still ring ) until you remove either the +12v or the 0v in the bell box ….all the rest is correct….ps … you only need to remove one of the battery leads in the bellbox
