First things first you should measure Ze, if Ze is above 0.8 for a TN-S or 0.35 for a TN-S its time to complain to the supplier.
once you know Ze is ok then its time to go back over your design calculations ,check for bad joints and test that the resistance of cables is what it should be until you find the problem.
but if this isn't obvious to you then it's imo a sign that you aren't really competant to be doing electrical design/installation work.
iirc on some RCBOs the RCD aspect is unsuitable for use for protection against indirect contact, they need to operate in their overcurrent mode. (something to do with the RCD electronics requiring a certain amount of voltage to remain effective.)
