Adding 3 PIR lamps to an existing circuit via 5amp FCU
10 May 2008
Liverpool
Anyone any ideas I have to branch off a ring main cos the lighting circuit is wired in singles and I have to put in a 5amp fuse spur from a double socket on the ring main and I alsohave to put in a switch and 3 PIR lamps 150w each) and I have a 20amp 6 terminal JB which is doin my head in as to wire them correctly as its hard to get all cables in the JB and in the correct sequence anyone know how? Appreciate any info.
well if you want one switch to control them all the live goes to the switch first , then back to the jb.
all the lights are still wired in paralel.
the lives go to the switched live the neutrals and eartyhs go to their respective terminals
I kinda understand but what I mean is where do they all fit in the JB as there is the supply from the 5amp FCU the switch wire and 3 lamps all in the JB seems rather cramped would not what you said means that the switch would do nothing and they would all be permanently live.
