Adding a shower room - door size etc?
18 Oct 2006
Norwich
Afternoon all
I'm encouraging my father to have a downstairs shower room/WC installed in his house as the only WC/bathroom is on the first floor - not good as years progress.
I think we can take some space from a downstairs room to construct it. Would BR insist on a certain size of door to the room or can you get away with the old 30".
Are there any specific issues about installing an extra shower room that you gurus think we should be aware of...we hope to use a 'grundfoss maceraor' to get the waste from WC/sink/shower to a nearby stack.
It won't be a DIY job but just want to know that any proposed design will wotk before talking to the pros.
thanks
Welsford
Macerators are a bit rubbish frankly so don't be surprised if you're replacing it in a few years but they can get you out of a hole so to speak if there is no other solution.
There is no minimum size of door as you are improving facilities rather than reducing them.
Thanks - that's good to know - when we had a shower room built we had a wider door fitted...but don't know whether that was what the architect thought or was a requirement from planning/BC.
Yes aware macerators are not as good as gravity...but one man living alone with only human waste going down it....no condoms (i hope!) or sanitary towels etc which should make it a bit better...also not much of a vertical lift/horizontal run and it will probably be in 40mm.
