Advice on adding two double plugs onto the main ring via a fused spur
22 Aug 2024
We were recently quoted by three electricians £370-£470 for doing this and sadly we don't have the money and it's somewhat urgent (see additional information).
I have spoken to my uncle who used to do a lot of DIY when it comes to electrical work and while I trust him i just wanted to run it by a few more people.
I'd like to run a fused (13a) spur from the main ring, and add two double plugs a few meters between each other. Here is a very amateurish diagram
Questions:
1: Is it okay to run a single wire from the first (main ring) double socket to the fused amp? I've read it's safe but many prefer to just add the Fuse to the main ring. The wires behind the double plug aren't long enough to stretch to add to the ring. Is daisy chaining okay?
2: Is it okay to daisy chain The cable coming FROM the FCU to the two new double plugs?
3: Does this diagram look okay? I'm not asking for critic on my 'art' lol.
4: Is 2.5 mm² Twin and Earth (6242Y) cable the correct cable to use?
Additional info:
I am not trying to trauma dump just explaining why it's 'urgent' and we can't afford that money. We moved into the house about 2 years ago and my wife became ill. We were told it would take about 2-3 years to recover. Sadly, last week we were told it's terminal and she has about a year left. Maybe 18 months. I've had to give up work and i'm on U.C and £400 is just not possible.
The room these plugs are going in used to be our 'gaming' room but will become her bedroom as it's on the ground floor near a bathroom. Sadly the room has one plug and we need at least three.
I did post this question on reddit and got called a liar and was making up the story for 'attention' or donations (I wasn't) incase anybody feels that way here, here is a previous post i made before we knew she wasn't going to get better. Once again, not trying to trauma dump i just don't want to go through what I did on reddit but explain why we can't afford that at this moment and time is somewhat important.
Sadly these days there are all sorts of reasons why people can't afford to find £40 let alone £400, we all understand that here.
1: Yes it's fine to have a single spur from the ring to the fused connexion unit.
2: Yes that's fine.
3: Nothing wrong with your artwork, it's clear and concise
Are you be going to put any heavy loads on the new sockets. The reason I ask is that if you need to have them available urgently could you not just use ready made extension leads
The plugs will be used for a hospital bed, a hoist type thing which weve been told need to be plugged directly into a wall socket. I wanted an extra double incase anything else came up in the future with the same requirements. Other things like a TV, a laptop, an electric photo frame etcbut that stuff can be put into gangway plugs etc. :)
2: Yes that's fine.
Thank you for your reply and good to know all the info ive been given is correct. Honestly, ty.
