Hi. I need some advice please. I have a Drayton MA1 3-way valve unit. Ive had it in the garage for a couple of years but now thinking its time to fit it. Thing is, when I look inside at the rubber valve gate, I see that it touches the pipe ends on the hinge side but leaves a gap on the far side. Is this normal? Will the water pressure or temperature cause the rubber gate to close fully? Has age affected the rubber gate and is pointless fitting this? As I don't have another valve to compare it to I thought there might be a plumber on here who has one they could check. Many thanks.
Another forum post suggested the Honeywell valve as it has a ball gate instead of this flat face gate. I assume the ball makes a good seal each time as it sites in the cup of the open pipe. Should I scrap the drayton and get a Honeywell? Are the motorised heads on a Honeywell easy to swap? Many thanks
