worked out that the pipe diameter just below the pump is 28mm, so I'm going to order the Spirotech MB3 28mm as the video looks pretty straight forward to fit... It says on the installation video that that it must be installed with the arrow following the flow direction, am I correct in saying that where I'm going to install just below the pump that the flow direction would be pointing down towards the floor going back to the boiler in the kitchen downstairs ? OR is the flow coming out of the boiler which would then mean that the flow is going towards the pump I.E UP....
If anyone could pls help me out on the flow direction I'd be obliged
