I need to install a T connector off an existing 15mm mains water pipe, access space is severely limited as it is under the 1st floor floorboards and surrounded by a mass of other pipes for central heating etc.
I presumed that I would need to use a compression T as there is likely to be water still in the pipe once it has been drained.
Is this definitely the case or is it possible I will be able to solder one in instead? (It would be very difficult to get spanners onto the nuts with the lack of space)
