- Joined
- 11 Sep 2024
- Messages
- 2
- Reaction score
- 0
- Country
I'm looking for advice on a fireplace we have inherited, we organised a service and the engineer said ventilation was a required, transpires this has been blocked up since 2005.
We had a copy of the last gas service completed by the previous owner on which 'Ventilation' was marked as pass. The engineer was not impressed and said if they had inspected the vent they would have seen it was blocked...
I contacted the company who did the orginal certificate and raised my concerns they arrived in 5 minutes unexpectedly! They were not happy with the suggestion from the other engineer and stated an air brick wasn't needed as there is adventitious air, they changed their minds after I was unable to produce the MI booklet and therefore said the vent needs opening.
I have tried finding the manual for this fire Crosslee Royal CozyFire 16" Inset Taper with no luck, nothing on the web.
Guidelines are confusing and suggest an open flue fire under 7kw MAY need additional venting depending on spillage test results, but exact requirements will be indicated by the MI so I suspect they have erred on the side of caution.
What do I do? I love the original fire but this vent is ridiculous, I live by the coast and the vent is just not acceptable.
I'm due to get a carpet fitted soon and wondered if a spillage test could be requested and if passed therefore satisfying the need to not need this vent.
I find this all rather odd as I can't believe since 2005 the fire hasn't been used once... if only I could find the manual!
