- Joined
- 26 Oct 2021
- Messages
- 5
- Reaction score
- 0
- Country
Hi, looking for some advice on the roof installation, for a garden office/outbuilding.
The building is constructed from brickwork, double skin, with cavity wall insulation (50mm).
It will have a flat roof, span of 3metres. The joists will be 6 x 2, large roof, there will be over 20 joists in total, with an overhang of about 20mm all the way round. The fall will be around 50mm for every metre, 18mm OSB3 boards on top. Then EPDM rubber roofing on top of the OSB3 boards.
Question 1: Should I use C24 joists or will C16 suffice? I’m within permitted planning rights with the area and roof height, so no requirement in terms of building regs.
Question 2: Do I need to fit a wall plate on top of the inside skin?
Option 1 would be to fit a 4 x 2 wall plate on the inside skin, on top of a bed of mortar, and then secure it down with restrainer strips every 2 metres. The joists then sit on top of the wall plate. I’m a bit confused with what to put on the outside skin. Another brick could work, but the brick is 65mm, whereas the wall plate is 45/47mm. So, the wall plate will need quite a bit of mortar to raise it to brick level.
Option 2, don’t use a wall plate, secure the 6 x 2 joists directly to the inside skin of blocks using twisted restrainer strips, not sure if I need these on both sides or just one. This will also save me 2 inches on the height.
Can anyone advise please on the above
