From what I understand you have the TV aerial coming into your downstairs lounge, into a booster, and then outputs to lounge TV, kitchen, and a cable going back outside when then re-enters the house in the bedroom?
I would suggest buying one or two simple Y-splitters (about £2-£3) to split the upstairs signal between the TVs and PC, and seeing what the quality is like from that before trying anything else. Boosters tend to amplify the signal more that you actually need, so the split signal could still be strong enough.
If you use make up your own cables using CT100 or WF100 (satellite/digital grade) coax cable and fully metal plugs for all cable runs, rather than any cheap Argos aerial extensions or cables made from "low loss" coax (which isn't low loss at all!) you will minimise loss over all these long runs you have around the house and the signal could well be sufficient. CT100/WF100 is also fully foil-screened, thus greatly reducing the effect of any electrical interference.
Boosters can't regain any signal lost over long cable runs, they can only boost what is left of the signal they do receive. If you take a picture, photocopy it really small, then photocopy the copy and blow it back up to full size the enlarged picture is the same size as the original but the quality of it won't be any better than the really small version. What a booster basically does is the enlargement part of that process.
For that reason, it's always preferable to put the booster as close to the source as possible, so you are amplifying the signal before any serious loss can occur. If you can, I would put the booster in the loft. If the cable currently doesn't enter through the loft but runs down the outside of the house find an opening in the eaves where you can push the cable through into the loft, cut off any excess and connect it to the loft booster. Then you can have your outputs in nice short runs directly to the upstairs rooms where you need it, and to downstairs go back outside (if necessary) down the wall (using nice new CT100/WF100!) to the lounge.
...or watch less TV
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
