Afraid to lay 20 tiles!
7 May 2006
OK, a bit dramatic but I want to get it perfect 1st time.
The tiles are large format 600mm X 600mm floor tiles.
From my research a flat surface = success, so I decided to put down self levelling compound over the undertile cables.
The surface is level, although the compound has not created a totally flat surface.
I dry laid approx half of the tiles to see how the small variation affected how the tiles sat. What I noticed was some of the corners kicked up 1 - 3mm, not all the tiles but a few.
So the question (finally:cool: ) .....
Should I rely on losing these variations when I stick'um down (20mm U notch trowel (as per sticky))?
or plan b,
Go over the high spots with my orbital sander prior to laying and get them perfect pre-adhesive?
The flatter you can get your floor, the easier it will be to tile. If you can be bothered getting it better, then your finished job will be better too. For tiles that size, you ideally want it so that you can drop the tiles down dry and they'll be pretty much "bob on", then when you fix them down properly, you'll be asssured of a good job.
I'm inclined to sand down the high points, I don't want to look back on a less than perfect floor and I think, 'if only ......"
