Having the thermal store with the woodburner (and a loading valve to manage condensation issues in said woodburner) makes the system much more usable-without the store I had to be very precise with airflow and fuelling to keep woodburner at the right temperature so the radiators elsewhere worked properly.
My gas boiler runs happily vented or unvented so it (and the woodburner) are heating the store directly- the other option is to use coil(s) in the store so your pressurised boiler heats indirect. I'll dig the link to the bunch who built my store out-decent prices and options.
F and E tank for the thermal store- yes you'll need one, metal, at least 10% of the volume of the store plus rads, pipework etc.
Hot water-up to you, if mains pressure is good you can use either another coil in the store or an external plate heat exchanger- either way no header tank needed and no G3 installation either.
