- Joined
- 8 May 2017
- Messages
- 10,698
- Reaction score
- 2,900
- Country
fingers crossed then
but did you close off mains cold to loft tank ? I ask again, as if you did ,and drained out the cold ,when putting stopcock back on Any sediment loosened will possibly partially block the inlet valve to the loft tank ,causing it to fill slowly or not fully. this may explain the low level in the loft tank. if the loft tank starts to empty as hot water is drawn off ,and is not being replenished fast enough ,air will enter the pipework via the outlets in the loft tank ..its a possibility.
