    Dismiss Notice
Alternative to A142 mesh?
Discussion in 'Building' started by Pickup, 24 Apr 2014.
  1. Pickup
    Pickup
    28 Oct 2009
    132
    Thanks Received:
    6
    Aberdeen
    Country:
    We've been given plans for a new porch 1.8 x 2m which specify a floor with a 100mm concrete slab with A142 mesh on an insulated foam base.
    Local suppliers can only supply A142 mesh in 3.6 x 2m or bigger which would leave me with a whole lot that I don't need and would have problems disposing of. Is there an alternative (thicker slab or alternative material to the mesh).
    F
  2. Sponsored Links
  3. Static
    Static
    20 Dec 2005
    2,026
    Thanks Received:
    168
    East Sussex
    Country:
    Loose bars 6mm at 200mm centres each way.. but you may find that more expensive than the mesh. Not sure how you would have problems disposing of the steel.. either resell the extra or double up the mesh in the footing
    • Thanks Thanks x 1
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Sell it on ebay?
    Look on ebay for a smaller piece, or a supplier who will cut to size?
    Use the leftovers to build a compost heap?
    Given that you/your builder will have to have the ability to cut the mesh, cut it into pieces small enough to transport to the dump in the boot of your car?
    https://www.google.co.uk/search?q=fibre+reinforced+concrete+alternative+to+steel+mesh
  5. munchingB
    munchingB
    21 Mar 2013
    501
    Thanks Received:
    25
    Suffolk
    Country:
    probably cheaper to buy the mesh and a cheapy angle grinder than buying lengths of rebar...that will still need cutting!
  6. tony1851
    tony1851
    23 Feb 2012
    9,592
    Thanks Received:
    1,431
    Manchester
    Country:
    Might be a dumb question, but why do you need mesh in a small porch slab?
    • Thanks Thanks x 1
  7. Sponsored Links
  8. ree
    ree
    6 Feb 2014
    3,193
    Thanks Received:
    451
    California
    Country:
    What nonsense the plans specify - there's no need for mesh or rebar in such a small, domestic area.
    Add fibres to the mix, FWIW, and leave it at that.
    Historical slabs were poured for ever without mesh - though i admit commercial or heavy use areas benefit from mesh or re-bar.
    • Thanks Thanks x 1
  9. jeds
    jeds
    16 Apr 2004
    4,085
    Thanks Received:
    526
    Country:
    Leave the mesh out. It's not necessary.
    • Thanks Thanks x 1
  10. Pickup
    Pickup
    28 Oct 2009
    132
    Thanks Received:
    6
    Aberdeen
    Country:
    Thanks folks,
    I don't know why the plans specify mesh although I suspect that the architect may have taken some existing plans (for a much larger building) and "tweeked" them or just cut and pasted "appropriate" text.
    Cheers
    F
  11. munchingB
    munchingB
    21 Mar 2013
    501
    Thanks Received:
    25
    Suffolk
    Country:
    architect? porch? ..you mean porsche right? : )
  12. Pickup
    Pickup
    28 Oct 2009
    132
    Thanks Received:
    6
    Aberdeen
    Country:
    Porsche? Nah that's next door neighbour.... seriously tho we were getting drawings done for planning permission & building warrants and he "threw in the porch drawings for free"
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
