Question. Does a power shower increase flow rate or pressure? i.e. having 0.1 bar pressure currently from header tank (1 metre height from bottom of header to top of shower).
Cold water tank in loft feeds into bottom of copper boiler in 22mm pipe, hot water is heated from downstairs system boiler (Vaillant Thermocompact). Then returns to copper boiler for storage until used for shower and taps.
Will a power shower increase the pressure to at least 0.35 bar, or does it only increase flow rate?
Would replacing with a sequential thermostatic bar mixer provide better shower pressure?
My current shower head requires at least 0.35 bar pressure to work effectively, currently I'm assuming it's 0.1 bar due to the height between bottom of header tank to top of shower head.
