Always remember.........
14 Sep 2006
Gloucestershire
.......to make sure the plugtop is not wet :shock:
JohnD said:
Are you sure that was the cause?
Yes, a water/oily mixture is all I can assume as the plugtop was wet after the event and one new socket and plugtop later all worked/tested fine
That socket front will clean up.
Bet there was a fair old pop when that went! :lol:
I suppose it fell in the sink, rather than just being handled with wet hands.
Was it your house?
Aren't the RCBOs working? :lol:
No, it was on a machine at work.The operator tried to plug a 110V Tx into it for a process vacuum cleaner and he said there was a bit of a pop.
(No RCD - just a B32 mcb feeding 4mm² radial)
If you look the neutral pin has remained in there
