Yes. Switch off and then pull out the appropriate fuse. You will need the correct rating of fuse wire.I need to check if a fuse has tripped,
Where have you been?never seen anyhting like this before. Thanks!
it's a fuse. It doesn't trip, it blows (melts)
buy a card of fusewire from an old fashioned hardware or electrical shop. You will need (get) 5A, 15A and 30A
your yellow holder is for 20A. Not sure that will be included. What's it for? Storage heater?
the white dots are 5A for lighting; the blue is 15A usually an immersion heater; the red are 30A usually for sockets or a cooker; though you seem to have a lot.
look for the makers name "Wylex" on them, if so you can buy a few spares that will be convenient ib future. you need a small flat screwdriver to change the fusewire.
you MUST turn off the main switch before removing or replacing a fuse, as there may be a flash that will startle you and erode the contacts
you pull out the holder by gripping the projecting lips at top and bottom of each. Inspect it with a torch or in good light to see if it has blown; if there is any other damage; and to check that some numbskull has not mended it with something wrong.
yours looks like a Wylex Standard (or a rebranded copy)
you will probably find the receptacles that the fuseholders plug into are coloured, to prevent you plugging in the wrong one.
Was it a white lighting fuse that blew? and was it at the same time that a lightbulb failed? was it a spotlight?
Only ever seen MCB's before. So instead of these tripping and simply moving a lever I actually have to replace a wire/fuse with this house's electrics?? Man thats so annoying, why would anyone NOT have MCB's.
If you want mob's look here replacement mcb for old fuses but as has been said fuse wire is a lot cheaper & rarely blows unless overloadedOnly ever seen MCB's before. So instead of these tripping and simply moving a lever I actually have to replace a wire/fuse with this house's electrics?? Man thats so annoying, why would anyone NOT have MCB's.
I still have a SH Crabtree 6 way and a load of MCB's here, I've done loads of work in schools where there are still loads in service...an old house that has not been rewired for many years, and/or belonged to a very mean person unwilling to pay the extra for MCBs.
Yours looks like it could be 50 years old.
I had some aunts who had a bungalow built around 1960, no expense spared, and had a metalclad Crabtree C50 CU with circuit breakers (bigger than today's ones).
it was still working perfectly when I had to clear it out many years later.
I still have 2 in use in my house, granny annexe used as workshop/junk store and shed. However several fuses have been replaced with MCB's:I need to check if a fuse has tripped, never seen anyhting like this before. Thanks!
