The plastic back started a touch before that, in 1983 I purchased & fitted two (8W & 4W) from same wholesaler at same time, I had one of each. Earlier than that (~1974 or 5) I remember being offered brown or cream from stock. I imagine stock levels crept into the changeover sales.My step Mum has an old Wylex with a wooden back. Dates from 1970 as the wiring is metric.
Hers is brown. AFAIR, the ivory ones with wooden back date from around mid to late 70s to 1985 ish. They then moved onto a plastic back.
There was nothing to "get away with" he will have known that nothing on the circuit was switched on so no danger of an arc being drawn or sticking his fingers where he should not.This is like mine that i want to upgrade
The electrician that rewired a light for me recently pulled the cartridges labelled for the lights but didnt turn the main power off?
I havent had issues since so got away with it, but worried to see it shouldnt have been done that way
Ahh thanks, so if it had been say a 30A cartridge (labelled sockets), main power would have gone off due to the risk of something drawing power on the fuse?There was nothing to "get away with" he will have known that nothing on the circuit was switched on so no danger of an arc being drawn or sticking his fingers where he should not.
I wouldn't say 'mainly aimed at DIY'ers', I would say - it's the safest way we can advise anyone to remove a cartridge fuse, without being able to judge their ability and the safety of their electrical system, on a public forum!Switching the power off at the main switch is mainly aimed at diyers
Only ever seen MCB's before. So instead of these tripping and simply moving a lever I actually have to replace a wire/fuse with this house's electrics?? Man thats so annoying, why would anyone NOT have MCB's.
Because MCBs have not always been available. Rewireable fuses have always been and still are acceptable today.Man thats so annoying, why would anyone NOT have MCB's.
As has recently been pointed out in another thread, arcs are my no means the only risk. For example, the fuse holder can disintegrate (to lesser or greater extent) when pulled, possibly leaving pins sticking out of the terminals and ends of over-long bits of fuse wire can be poking out waiting for some unsuspecting person to touch them.There was nothing to "get away with" he will have known that nothing on the circuit was switched on so no danger of an arc being drawn or sticking his fingers where he should not.
As I said in a later response I think is down to the individuals risk aversion. The examples of possibilities you suggest are not things I have ever come across in 50 years but I am not saying they don't exist, what does concern me is that some of the replies are possibly reinforceing the doubt the poster seems to have in the competence of his electrician. That is the way it reads to me anyway.As has recently been pointed out in another thread, arcs are my no means the only risk. For example, the fuse holder can disintegrate (to lesser or greater extent) when pulled, possibly leaving pins sticking out of the terminals and ends of over-long bits of fuse wire can be poking out waiting for some unsuspecting person to touch them.
I suspect that most/all of us have 'done it' in our times (and "got away with it"), but that doesn't alter the fact that pulling one of those fuses without first switching off its supply is potentially dangerous, for anyone.
Kind Regards, John
