I thought I had seen most things, but.....
Kia C'eed, 07 plate. Had to replace a flexible section of the exhaust, due to it leaking. It had flanged ends, two stainless studs on each end.
The original nuts, as expected were ferociously tight, so out with the gas axe and they wound off without too much trouble.
New dealer nuts (12mm metric fine, 20 mm long) purchased and screwed on.
Again, these were tighter than expected but I persevered ....and then the inevitable happened - the stud sheared off.
I managed to sort the job with an ordinary nut and bolt, but it transpires that when fitting these new nuts, they must be heated up to red heat too - and it usually takes 3 reheats
Live and learn!
John
Live and learn!
John
