Angle Grinder
When things return to normal in a few months times...... Lidl & Aldi cutting/grinding/diamond discs/flap wheels are good value for the money.
They're usually 125mm but you can fit them in most 115mm grinders
If you don't have one, get a Milwaukee quick release nut (about £7.50) - a lot simpler and cheaper and smaller than the Bosch SDS clic ones.
I had seen the Bosch ones and I could not justify spending that much on something I would only use once or twice a year. I had not heard of the Milwaukee one until now, but I ordered one (£6.95) and it seems to work fine. Thanks for the info.
Just make sure to check the speed rating is OK when doing that.
