Another boiler filter question!
11 Nov 2010
London
Apologies, my first post and it's probably been covered many a time before. It's not my first visit though, and I'll give thanks for the info I've taken from this site previously: a god send for the amatuer like me.
Anyway, the heat exchanger in my boiler keeps getting clogged up (with 'gunge' according to BG. Limescale as far as I could tell.)
What type of filter is it I need to fix? I think it goes on the heating return, but someone might correct me if I'm wrong.
Thanks in advance.
Aside from saying thanks for pointing me in the right direction, what is the difference between the two? I thought my boiler only had one........!
the first two are for the primary side of the system (heating)
the combimate is for the secondary side (hot water)
asyou don't say what type of boiler you have ive covered both :idea:
Thanks again.
It's a combi boiler, and the problem is coming from the heating return as far as I have been told. I assume I need your combimate.
Really appreciate your help.
Keith.
Bloody hell! I'm not only an idiot when it comes to DIY, I'm one in general!
Kev, you're a legend. Thanks once again.
There has been quite a few problems with the Magnacleans leaking (my own at home included). I've switched to the Fernox TF1's which work in the same way and are priced the same
Don't fit one of these expecting it to cure your problem completley, i've seen many clogged heat exchangers even with these fitted. For your system a good powerflush and dose of inhibitor would be better. More expensive though!
