I know there are a lot of these posts lately, sorry to add another but have a couple of questions - sorry also for the long post, will try to be logical with it...
Firstly, in the new extension, its a concrete floor, so the builder has run some new sockets (extending the ring from the old half of the kitchen) in over the ceiling and down the walls. He left a loop of one of the ring cables exposed out of the wall to the side of the cooker with the intention of using it for an FCU for the hood. The circuit then continues down to a double socket right close to where the cooker is going and back up to feed the rest of the extension.
The current cooker is a 3yo power-hungry freestanding one that we've decided (last minute) to replace with seperate hob and single oven.
It runs off a 45amp cooker switch (via a connecting point), on its own circuit - I'm not sure what the ratings of the circuit or the cooker are at the moment but will check when I get home. I'm suspect it's 40amp+ as I specified that several years ago when the cooker circuit was installed.
Reading previous posts, I'm thinking it's better if I get a single oven so I can run it from a 13amp FCU, I can then use the original cooker point to drive the hob (which is likely to be an induction type).
My questions (finally! ) are..
- Is it possible/acceptable to convert a double socket into two FCU's side by side? One to feed the hood, the other to feed the oven? Or...
- Should I convert it to a socket + single FCU for the oven and still use the loop higher up for an FCU for the hood?
- Whether I use the loop or convert the socket, I'll need to chase the feed horizontally across and round a corner to get to the hood, or better to chase down under worktop level, then across and back up the wall directly behind the cooker.. would either be acceptable?
Thanks for any advice, and your patience.
