Hi, I am installing a seperate oven and hob into my new kitchen. as well as trying to keep my bases covered for future upgrades. Therefore I am using 10mm T&E ran from a 40A MCB.
Problem been my oven has a 13A plug attached and as usual says warranty is void if you remove the plug.
I want to try and set my system up so it is as simple as possible for future upgrades. Therefore I have thought of doing the following and would appreciate any advice if it seems the best way to do it or if there is a better way.
I am thinking of running my cable to a single 45A oven switch above my work tops and then this will drop down to a 45A oven switch and 13 A socket (fitted behind an access panel in my cupboards), this will let me plug my oven in, then I will need to run a cable from this oven switch to a speperate oven connection plate so I can hardwire my hob in.
I know it is all probably overkill but i just wanted to run all my cooker appliances from one switch.
Any Comments appreciated.
And yes I know it is part P work and I have all the relevant council forms to fill in.
