- Joined
- 5 Apr 2004
- Messages
- 45
- Reaction score
- 0
- Country
hello
I've asked a lot of questions lately (first DIY kitchen install
) and I've had a lot of really useful advice and reassurance (thanks to everyone, particularly JohnD,Jasonb,letiss,Trazor, ricicle and Dingbat).
So here's a last one (for this time anyway
The last job I need to do is cut out two holes in the worktop for the hob and sink.
It's a 27mm thick solid beech worktop. It was supplied square-sectioned with no post-formed edge and I've kept it like that; I've just done a 4-biscuit+3 bolt butt joint in an L-shape as recommended by the supplier
http://www.hardwoodfloorstore.co.uk/worktops/worktop_installation_1.htm
and it 's worked fine.
(Bit of luck, my walls are very nearly 90 degrees. I had to chase into the plaster a bit but not much).
My router did a fair job of biscuiting+bolting the worktops but it's a bit weedy (Einhell 1020W). I do have a decent jigsaw but I don't really trust it to cut squarely through 27mm without creating a misshapen hole underneath. If I use the router to cut the holes I'm worried about scorching the wood as well as making a hole which the hob and sink will sit tight in. Do you think if I took things steady,in say 3mm passes I'd get away with using such a low-powered tool
I see from other posts the pros recommend 1600W+.I have 2 unused Trend 12.7mm bits for the job.
This will be the second time I've used a router (first after doing the join!). I did read up on them and have practised a bit and I do reckon I've got it (well, haven't made my first big mistake yet!)
I do have a reasonable-looking jig to guide the router which came with excellent instructions
http://cgi.ebay.co.uk/ws/eBayISAPI....Sell_LogicX&refwidgettype=cross_promot_widget
Tomorrow could either be a very good day or a rather bad one.
Jigsaw or router? How would you do this?
Advice, as always, appreciated.
