Hi there first post and new to forum so please bear with me,
I moved into a Barratts new build last October and since then have had problems with both heating and hot water but mainly hot water.
My system comprises of,
Ideal Icos boiler (HE Range)
Drayton Lifestyle dual channel programmer
Range Tribune HE storage/immersion tank
The main problem is hot water running out after two showers of no more than five minutes each approx, we have the hot water programmed to come on at 05.00-06.30 each morning, and 16.30-18.30 in the evenings.
Both showers are taken before 07.30 and 90% of the time the hot water runs out half way through the second one.
So far we have had changed,
Water pump
expansion chamber (now need a second one due to noise)
fan on boiler
Thermostat on storage/immersion tank
system flushed due to grit in pipes.
I have had an ideal agent round to check boiler (fan Changed) on attaching his thermo leads to inlet pipe and out let pipe for temp readings on boiler it took atleast 5 minutes to reach 52 degrees, and no higher, on asking if any thermostatic valves were on radiaters which there are upstairs, (he looked downstairs in the room with the main thermo switch?) he asked for all valves to be turned off, on doing so the boiler started to climb in temerature although it took atleast 10 minutes to reach 81 degrees, lots of switching off and on of boiler to make sure it cycled then left on.
Then we turned on the thermostatic valves on the upstairs radiators the boiler took an absolute age to warm up bearing in mind that this was straight after it had got up to 81 degrees, it only reached 52 degrees and would go no higher, the agent said this was normal as it was running at full flow and takes time to get back to 81 degrees, this was after 10 minutes plus of waiting for his thermometer to rise which it didnt, he then just diconnected it packed up and left saying the boiler was fine.
Just how long should it take for the boiler to come up to temperature with thermostatic valves open ( 5 non thermo radiators down stairs 2 upstairs and 3 thermo valved upstairs). Three bedroomed new build end terrace house.
Also how long should I expect the water to stay hot in the storage tank, every other house I have owned has had the boiler fire up on demand of hot water this boiler doesn't it just seems to heat and not very well and send water to the tank.
Do you think the boiler is at fault and should be replaced, we were told by the installers that our boiler was already not made anymore when it was fitted, or could it be something else not working on the system like the dual controller?
many thanks for all responses sorry its a long one
Cheers Pete
Water pump
fan on boiler
Cheers Pete
