A
Alarm
On many multimeter's the 10A socket isn't fused at all. Yeah it's not a socket you use very often but even so you could still plug into it by accident. Even on ranges that are fused the fuses in cheap multimeter's are often only glass cartridge fuses.
If you are going to be using a multimeter for mains installation work at least make sure you get a set of approved fused test leads for it.
If you are putting your leads into that (10 amp) to test for anything apart from current then your not competent.
I check with that setting on a regular basis anyway, so not an error I am going to make.
As above it does not say anywhere YOU MUST NOT, it suggests another method of testing. Now I agree if your employer or indeed if it is in your own ISO or other manual then you work to that method.
Most decent meters have fused probes and a display saying what sockets to use on the equipment, same as for instance the Metrel Continuity and insulation testers. Also the meter carries two internal fuses. No display = check meter, easy really.
I use either and sometimes both my meter and combi when testing. Both before and after as you never know.
I have been caught out once, my own fault for not check, test check test procedure.
As before if it is in your work method statement then use the two probe method, if not use what is safe and TESTED. And double check.
