Anyone used a dust shroud for their grinder?
7 Apr 2005
Got some pipes to chop in was looking at one of these? Or should i just buy a chasing tool?
I do have a universal one it sort of works, reduces some of the dust but not all, a real pain to use with the vac hose attached though
I use a cheap chaser (less than £100 from either toolstation or screwfix).
The main advantages are constant depth of cut and both channels cut (parallel) at the same time.
Downsides are that it weighs more and you have terminate the channel slightly earlier if running in to a corner or the ceiling (because of the size of the shroud).
Dust extraction is pretty impressive, bar the initial plunge before the shroud is flush with the wall. The tool is quite heavy, so the attached vacuum hose is not that noticeable.
I bought a cheap one from ebay on a recommendation. It's a proper faff to set up, and doesn't quite fit on my old draper grinder unless I leave one of the securing screws off, however combined with my trusty and abused Henry vacuum, it makes a notable difference that is worth the grief. The tip with the plunge, is to pivot the grinder on the rear edge of the shroud, so more of the dust is captured between the wall and the shroud. Mine had a clear plastic case, which was helpful for seeing where you're cutting, ish..
I've seen some videos where people use a clear plastic storage box, without the lid
Cut a hole in the side and tape a rubber glove to it, another hole for the hoover pipe, then just hold the grinder with one hand and the box against the wall with the other. Seems to work reasonably well.
I have the bosch one and it eliminates most of the dust, it has various settings for depth.
Opps, would the one you have be able to go through stone rather than bricks?
