Appropriate primer for peeling surface
Discussion in 'Decorating and Painting' started by donmaico, 27 Aug 2020.
  1. donmaico
    donmaico
    11 Nov 2008
    254
    Thanks Received:
    Sussex
    Country:
    Hi I have wall which I want to line prior to applying emulsion to it but after removing the existing pare which actually came off quite easily, I noticed the top layer of existing emulsion peels off quite easily in certain areas, so I as wondering about covering it with an appropriate primer such as Zinzer Peel Stop. I see there are two variants, a green one and brown one both water-based.Could someone advise me please? thanks
  2. donmaico
    donmaico
    11 Nov 2008
    254
    Thanks Received:
    Sussex
    Country:
    i am using Zinsser Peel stop
  3. Sponsored Links
  4. opps
    opps
    16 Jun 2006
    5,380
    Thanks Received:
    866
    London
    Country:
    I normally just apply a coat of wallpaper paste and then run a scraper over it. If the water in the paste results in the paint being easy to remove then I am assured that any remaining paint is sound. It can be messy but it is cheap. the next day I lightly sand the wall and apply another coat of paste and hang the lining paper.
    I do the wet on wet lining paper/paste because I am too lazy to use two buckets, one dilute, one full fat. I also find that one hot days I can be assured that if the paste on the paper has dried slightly, there is still wet paste on the wall.
    I'd recommend using a roller to apply the paste to both the wall and paper. It is so much faster and easier to apply even coats. If you are working on old horse hair plaster walls it might be advisable to use a brush on the walls because of the risk of pulling out bits of grit. In those cases, I paste the wall, let the glue dry and then give it a light sand (to dislodge any grit) and then roll it and the paper. I also use a wide blade "knife" to smooth the paper and remove any air bubbles. One leaving site, I want the paper to look how it will when the glue has dried and shrunk back, another advantage is that when you apply the emulsion, you wont have any bubbles that look unsightly (even though they will shrink back).
  5. donmaico
    donmaico
    11 Nov 2008
    254
    Thanks Received:
    Sussex
    Country:
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
