I'm looking for some advice / suggestions around architects please. We are planning on having an extension to our 3 bed semi detached home, firstly a first floor extension over the existing garage to the side to add an extra bedroom, and secondly to extend out the back from the existing kitchen and dining room area. The upstairs bit *should* be fairly straight forward from a design perspective, but the downstairs I'd like to do something a bit more 'special' with some design flair (e.g. vaulted roof) subject to budget - see link at the end as an example.
We've had three different quotes so far, all from personal recommendations, but not really sure what 'level' we need to go for.
1) The first was from a chap who came across very much as 'tell me what you want then I'll draw the plans for you', though relatively cheap compared to the other two, but this wasn't really what we were looking for.
2) The second was from a local architectural services company (architectural technician), who came across well, has good examples of work, helpful, coming in at a little under £2000 (initial survey, planning drawings, building regs drawings). The concern I have over this is he does not appear to be listed on the ARB web site, and although qualified seems to be an associate rather than full level (uses letters Arch Tech ACIAT, whereas some googling suggests MCIAT is fully qualified). However he was very open that he is currently working for a larger homebuilding firm and in the process of setting up on his own, and his work and meetings are currently done out of office hours (though this suits me better anyway so in itself not a concern)
3) The third was a 'full' RIBA architect company, and again came across very well, but the quote was much more than the second option, coming in at nearly £4000 in total. I suspect our project is smaller scale than many of their others.
Questions as follows -
Thanks in advance,
Pete
- What differences should I expect between an architectural technician and a full architect, is the latter necessary or an overkill for this?
- Do the fees sound reasonable? (As an indication I'm hoping the total budget would be somewhere around 100k)
- Are there any risks by using an Arch Tech if not ARB listed that I should be aware of? I would check he has some level of professional insurance, and I assume the process of planning, building regs and structural engineer work should be expected to give confidence in his plans?
Thanks in advance,
Pete
