Are these hole saws worth keeping?
23 Mar 2007
Cheshire
I was looking for something to drill a hole with and found these which I haven't seen in a while. I went to use one and noticed that the drill bit in the arbor is bent. It's a little special and has a flat so a screw can be tightened against it. I'm sure I could source a replacement drill bit online but I was wondering whether it's worth it. The saws themselves seem pretty flimsy. I'm not sure it's worth replacing compared to getting more solid saws.
They have their uses.....strictly DIY and thin stuff.
It's easy enough to grind a flat on a new drill - if you have a grinder- or even file one. It doesn't have to be much, just enough for a screw to grip.
John :)
Bin it! You can get some good holesaws from the toolstation Punk range - just buy a new size as you need it, so you don't have a huge outlay in one go.
Nozzle
