Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I've got 4 core armoured cable for a garden shed run but the cables outside diameter is 12.3 mm and the only junction boxes and joints are 10mm and I think 15mm. What am I doing wrong ?
The size of the glands to weather seal the cable needs to match the outer diameter of the cable surely.
My query is since the cable is 12.4mm diameter and no junction/joint with that size other than 10mm / 15mm what is wrong
