Does the water meter show the patch of bricks outside to be more moist than the other ones?
Perhaps it just needs a long time to dry out now?
Do you have any pictures of the house before you noticed the stain to confirm it was not there?
Just an update to this, had a further roofer out today who stripped the tiles off from the roof and it was bone dry (still had cobwebs below felt) wood underneath was also bone dry he replaced the cracked tile but explained this wouldnt be causing the issue due to felt as secondary was dry and would prevent this sort of issue happening. He also confirmed that roof felt was going into gutter.
Purchased a damp meter this shows 14% damp on the opposite wall inside but nothing on the outside?
Builder measured up between the green line posted above and this is the internal floor on the upstairs which lines up exactly, could it be pointing towards a possible pipe somewhere? I've had the water turned off 2 months almost but it hasn't dried up but nor is it getting even slightly better.
