Avoiding the gas or electric
10 Apr 2019
Apologies if this is in the wrong forum area, ive opted for the gas related forum...
I need to drill a couple of holes in the floor to fit a threshold plate between the hallway and an understairs cupboard which contains the gas and electric meters. It is a concrete floor.
Im concerned that I dont know where the gas or electric feed come from so there is a risk that I might hit them!
The threshold plate wants 50mm x 6mm holes.
This is the location:
Metal detector doesnt find anything.
I can only assume the 2 gas pipes and the electric incomer feed through the hallway, through the door and into the meters.
Any advice?
Mark
Yup, use a silicone adhesive, no need for screws. either that or use the proper threshold screws which I think are about 20odd mill
The plastic ones that came with it are 45mm thread length.
Plastic screws? What kind of threshold is it?
Nice lead gas pipe there too :whistle:
Yes when the DNO was out to replace the meters he did check if he had to remove the lead (April 2019). The answer was if it is in a good state of repair then it can be left as is.
It is a plastic "screw type thing" that has a ribbed type thread that isnt really a thread as it is discontinuous that fits in a t track under the threshold plate.
Ah right, it's the one with the channel in them, I'd just silicone that down.
If you want to use the plastic clips though then drill the floor just deep enough (say 15mm) and then cut the plastic clips to suit that depth with the floor covering added (say around 30mm?). I'd still put a little silicone on it to give it extra grip.
I silconed our threshold down a couple of years back and it hasn't moved. Just make sure you put plenty on.
I used the No-nonsense stuff from Screwfix, really good silicone to be fair.
I haven't had the time to do it yet. I have another threshold bar that I put back down with no more nails, but that didn't last very long...!
Evostick it...it's only a cupboard threshold.
I'd get the lead replaced...all it takes is a knock from a hoover.
